跳转到主内容
A2115 / 2020 / Processors from 3.1 GHz 6-core i5, up to 3.8 GHz 8-core i7. Released August 4, 2020.
Why is it slow to boot up
very slow to boot up and runs slow after installing big sur
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Reboot your system and press the D key to enter into diagnostics. Did you get any errors?
Reference: Mac startup key combinations
完成的
添加一条评论
1个答案
最有帮助的答案
If your computer still has a standard hard drive or fusion drive, I’ve noticed quite a lot of them running very bad on BigSur. I would suggest either replacing the hard drive of the fusion drive with a 2.5 inch SSD or going back to macOS Catalina.
这个答案有帮助吗?
得分 1
2条评论:
Where is the hard physically located? I'm having a very hard time disconnecting the cables from the display or the chassis. I have purchased a SSD that I will try to install if I can get there.
完成的
添加一条评论
添加你的答案
Richard Buckle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 334
