跳转到主内容
Repair guides and support for Kenmore washing machines.
Why won't my kenmore washing machine powering on
Kenmore washing machine (model 40272900) won’t power on unless I unplug and plug back in. Single circuit to the washer with GIFI outlet remains powered. Once powered up it runs through a whole cycle but once it is done I can’t run another load without unplugging and plugging back in.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Some machines must be level and the load in the machine must be balanced. When you unplug and plug back up you are resetting the safety controls on the machine. As your saying it does this every time I would make sure the machine is level.
这个答案有帮助吗?
得分 0
添加一条评论
Is there any indication there is power to the machine? If so, is there any error codes? If not, it sounds like you have a failing controller. It would be a lot cheaper just doing your unplug routine.
这个答案有帮助吗?
得分 0
3条评论:
I have a similar issue with my machine. I am sure there is power at the wall. However, I get nothing after unplug/plug.
完成的
Kenmore 40272900
完成的
This morning, my wife tried the power button and it works now. This machine has done this a few times now.
完成的
添加一条评论
添加你的答案
Reginald Jones 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 193
