跳转到主内容
The Bose SoundLink Mini II is a Wireless Bluetooth Speaker that delivers high quality audio from a compact design. The device weighs approximately 1.5 pounds and has a Bluetooth range advertised up to 30 feet. The device was released after June 26, 2015 and is Identified by model number 725192-1110.
There is little or no response from the buttons
I get a small flash of light from the power/charge indicator when I disconnect the USB Charger. I get similar response if I disconnect the cradle supply but only if the USB is plugged in as well. Some devices see the Bose through Bluetooth but do not connect.
Battery tests good.
The speaker doesn't power on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Did you tried this solution?
Bose Soundlink Mini II Microschalter / Tasten Reparatur
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paul Lakin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 88
