跳转到主内容
A large smartphone by LG, released in fall 2014. The LG G3 (D855) boasts a Quad HD IPS display and a 13-megapixel camera.
Won't power on not recognized by pc
I have an LG g3 I had someone bring me to try to pull data off of. Normally I'd just say it's dead and you're sol. I tried booting with battery in, and plugged into wall power, no go. No charger light shows, plugged into pc and it's not recognized. I haven't tried a new battery yet but I did try booting without battery and no go. I seems YouTube video that said it's the power button and common on these g3 and G4 I had a G4 myself personally this same thing happened to. I would not mess with it at all but the data is of a girl that was 7 that died. I'm trying to pull the data with my heart going out to the owner that this is where a lot of pictures of her are from before she passed away. I wanted to at least try everything in my power to get the data recovered. I seen a YouTube video but the dudes head is in the way of how he pressed the connectors on the Mobo to get it to boot. I also seen someone say something about putting it in the freezer to get it to boot. Haven't tried that yet. Has anyone run into this and is it usually the battery, power button, or what is common to try to see if I can at least get it to boot once to get the data. I assume there's no other way to pull data off of it if it isn't recognized via USB. I have plenty of forensic investigator tools but if I can't get it to power up or be recognized via USB I figure their a crap shoot. Could it be the usb port went bad? Looking for suggestions and recommendations to try to help this lady out. I planned to charge for the recovery if I fixed it or got them but hearing this story I don't have the heart to do that.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I'll give replacing the battery a shot. I tried the removal already no dice. I tried putting it in the freezer lol. I seen a video of someone doing something with a heat gun but I can't make out what he's doing because it's on YouTube and in a different language. But I'll see if that helps replacing the battery and report back.
完成的
Ordered a new battery got it to boot once and was able to recover pictures from it. Which was my goal it was for a lady who's seven year old died.. after recovering them it shut off and now has blue screen of death when booting up lol. But I'm not messing with it because she's not worried about fixing it since she got all the pictures!
完成的
添加一条评论
1个答案
已选择的解决方案
If the phone won't boot at all, the issue may be the power-related. Try removing the battery for 10 minutes, and then put it back in. Then try turning it on again.
If that doesn't work, try replacing the battery.
这个答案有帮助吗?
得分 0
1条评论:
I'll give that a try. Removal didn't work. I will report back. I seen a dude with a heat gun on YouTube to something but I couldn't make out what he was doing as it's in a different language
完成的
添加一条评论
添加你的答案
William Scott 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 477
