跳转到主内容
Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
139 个问题 查看全部
LG washer/drier 12/8kg has reset time back after switch off
Hello, my LG Washer/drier 12/8kg, model FH6GIBCHK6N was about 20 minutes into washing when my child switched it off, having a reading of 1:49mins remaining. When I just switched it on, the timer now reads 4:48 mins remaining. I thought that the memory would have picked it up from where it was. Is there a way to prevent this from happening or how should I reset it to back where the timer was? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
It sounds like your child turned it off at the wall outlet. If it was off for more than a few seconds most of the power would have drained from the machine resetting the internal memory.
You should be fine to set the time to what it was on and then restart the cycle. Prevention is kinda hard with this one other than trying to get your child to stay away from the drier and not to mess with the wall outlet.
If your machine does not let you set the timer to the custom time then just rerun the cycle. It’s not gonna harm any of the clothes, just clean them more XD
这个答案有帮助吗?
得分 1
添加一条评论
Hi @mobilityki ,
Your washer has a Child Lock option but I think that this won’t stop the machine from being turned off at the machine or the power outlet, merely from being turned on or the programs from being altered whilst the machine is operating.
Here’s an image taken from the user manual (scroll down the page to find the download link) that shows how to enable and disable it.
(click on image to enlarge for better viewing)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
newfriendlyuser 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 9
总计 81
