Loose Lightning Port (springs?)
Hello,
I tried charging my iPad but it only works with some charging cables and sometimes in only one direction. It also would say “Not Charging”. It also holds the cable loose. I took a look inside and found that the right tab that holds the cable is inward. How can I let it back out? And can this be a battery issue? Thanks.
Hey there,
Could possibly attach an image so I could have a look and help you?
Regards,
Myron.
由 Myron. 完成的
@iammyron07 I just added one. Best I could do. Thanks.
由 Munhib 完成的
Does it work with an original Apple charging cable? If yes, most probably it needs a new lightning port but if it does not and it only charges using a copy cable then it might need a charging chip replacement... Any how you can try your luck by changing the lightning port
由 Myron. 完成的
@iammyron07 It works an original with one side, not at all with a different original, and both sides with an Anker MFI certified.
由 Munhib 完成的
@iammyron07 My battery was also having issues (fast discharge, incorrect reading, etc.) as well, could that be the case?
由 Munhib 完成的
显示更多的1条评论
