跳转到主内容
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 个问题 查看全部
Home button touch ID swap temp to original
I know the MB and Home Button are married and that touch ID will NOT work if the home button is replaced. I misplaced my original HB so I got a new one. My question is: If I install the new one and later find my old one and put the original back in will the touch ID then work again? Or does swaping it, and then powering it on with a replacement then permanently disable that feature even if replaced back?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Anyone able to help with this?
完成的
添加一条评论
1个答案
Hey,
Replacing the old home button later on will just work fine until and unless you damage the button itself. Using a temporary replacement button would not hurt.
Cheers :D
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
TYSON PELTZ 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 26
