跳转到主内容
这是iPad mini 3(型号A1599)Wi-Fi版本的维修指南。这款iPad在2014年10月6号作为iPad Mini Retina屏版本(现在也做iPad mini 2)的新一代被发布。
Moire pattern on my screen after digitizer replacement
The digitizer glass on my mini 3 broke and I replaced it per instructions. What I noticed is that after installing it, there is now a rainbow/moiré like pattern on the top right that covers about 1/4 of the screen. Is this a defect in the digitizer glass? No screen protector and no obvious signs of cracked LCD…
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello,
I would first try disconnecting the digitizer and powering on the iPad to see if it still shows those symptoms, If it does its obvious that the LCD has been damaged and you need a replacement LCD! :D
这个答案有帮助吗?
得分 0
2条评论:
Thanks, I tired it and it's not visible with the digitizer flipped up. As soon as I put it over the LCD, the pattern appears.
完成的
Then, it's the cable itself. You need a new digitizer! :D
完成的
添加一条评论
添加你的答案
Jerry Lee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 140
