跳转到主内容
加入维修社区 - 创建账户
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
MacBook Air doesn't turn on after complete discharge of battery
Hey,
my MacBook Air 13” Mid 2013 was working fine up until this morning (never had anything spilled on it etc). I have been using it with an NVME SSD with an adapter for around a year without any issues. I replaced the original battery with an iFixit battery 2 days ago and everything was working fine, I had really good battery life again. I wanted to do the recommended calibration of the battery by fully charging it up until 100% and let the charger connected for at least 2 more hours, then discharge the battery completely to 0% and charge it up to 100"% again.
So what I did was: I charged it up to 100% and let the charger plugged in for a few more hours yesterday evening. Then I used the Mac for a few hours and left it turned on (via the App Amphetamine to prevent it from sleeping) until it reached 0-3%. When it reaches 3% (I think) it automatically shuts down to prevent complete battery drainage, but I thought I had to completely drain the battery, so I left the device unplugged like that for 4-5h more. To make sure, it was completely out of charge, I connected my smartphone to charge it with the last mAh left in the battery.
After that, I just plugged in the charger and let it charge until the charger showed the green light. And then I unplugged the charger this morning and turned the Mac on: No chime, no logo, no light, nothing.
I tried various things that were recommended on the web, watched so many videos, nothing helps.
-Resetting PRAM/NVRAM/SMC, didn’t help.
-Unplugging the battery and connecting the charger -> fan starts to spin, charger LED is orange, system doesn’t boot (no screen, sound, keyboard backlight) when pressing the power button
-Tried the same steps with the original battery and the original Apple SSD -> nothing changes
When I plug the battery back in and connect the charger, it starts charging the battery (orange LED) and turns green when it finishes charging (I guess). So I assume everything is fine with the battery (iFixit and Apple one)? And when I disconnect the battery and connect the charger, the fan immediately starts spinning, so everything is fine with the power circuit I guess? And when I press the power button (battery plugged in, charger connecteed) the fan starts spinning, so that’s fine too. Where’s the problem then?
I can’t believe this is happening. I have lots of important documents I need to access asap, my last time machine backup was a few weeks ago. I always kept my Mac clean, never damaged/dropped it, never spilled anything on it, why is this happening all of a sudden. Was it a mistake to fully discharge the battery?
Ah and if there’s no solution to this, can somebody tell me, if I can access my data on my NVME SSD via an adapter on a Windows/Mac device, to at least gain access to my folders (SSD was not encrypted with FileVault, but I had a password set for my user account, if that’s important)?
Thanks in advance for any advice!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Sadly you’re between a rock and a hard place ;-{
Using an M.2 SSD with an adapter in a Mac prevents you to use cases designed for Apple SSD’s like OWC Envoy Pro USB-A enclosure
Here you’ll need one that can support the M.2 SSD like this one Envoy Pro EX USB-C (Thunderbolt 3 Compatible) External NVMe M.2 SSD enclosure
So you’ll need a Mac with a USB-C port to read the drive. You can’t use a Windows or Linux system as Apples newer file system APFS is not supported in them. Even through you could get the add-on driver for Windows to read the older HFS+ based drives you are likely not going to be able to access the files unless you have a Windows based version of the application used to create it.
这个答案有帮助吗?
得分 1
4条评论:
This is great news, thank you!
So all I need is an external enclosure for NVMe M.2 SSDs and a Mac in order to access and transfer my files? That shouldn’t be an issue at all. At least now I know, that I’ll be able to save my files, thanks!
Is there any way to find out, why my Macbook is not booting up and what caused the issue I described above? I don’t understand what I did wrong, or if I did anything wrong at all. Could it be that the iFixit battery is faulty? But in that case it wouldn’t charge at all, I guess.
It’s good to know, that I’ll be able to save my files but it would be even better to be able to restore my Macbook to working condition, ideally with the iFixit battery I bought..
完成的
@eagle12 - Lets see if your SSD is still working first.
完成的
Oh no, is there a chance for that being the case? :/
I mean, I tried the Apple SSD too and nothing changed, I don't think that both of them could be defective.. and on top, wouldn't the MacBook show me the "question mark folder" sign, if the SSD was defective? As it is right now, it doesn't show anything and there is no startup chime either, only the fan spinning..
Anyways, I'll get the external SSD enclosure and comment here as soon as possible.
完成的
@eagle12 - Anything is possible. Fixing your system will need deeper skills as you have a logic board issue which will need access to the schematics and boardview and the skills to read them. Lastly, the skills and tools as well as the parts to fix it.
完成的
添加一条评论
添加你的答案
eagle12 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 1,061
