跳转到主内容
Repair guides and disassembly information for Apple's 8th generation iPad. Released September 18, 2020. Model numbers: A2270, A2428, A2429, and A2430.
39 个问题 查看全部
I can't see an iPad 8th gen replacement digitiser replacement kit?
I can’t see an option for an iPad 8th gen digitiser on the store, can you help? I want a good quality replacement part or if not available, which tool kit is ideal for the replacement of the digitiser? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
You’ll want to order the Pro Tech toolkit as it will have everything you’ll need and more to fix your iPad and other devices if need be. Pro Tech Toolkit
You can find replacement screens for the 8th gen on either Mobile Sentrix, Injured Gadgets, or Mobile Defenders. Mind you it’s just the parts you’re buying from them and they’re the top 3 parts suppliers and they back their parts with a solid warranty. Just create an account and order what you need!
Pro Tech Toolkit图片
产品
Pro Tech Toolkit
$74.95
这个答案有帮助吗?
得分 1
添加一条评论
iPad 7 screens are the same as iPad8 screens, most vendors will sell them seperately but if you can find an ipad8 screen then order one for an ipad 7
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Noah Derrington 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 12
总计 3,249
