跳转到主内容
A2115 / 2020 / Processors from 3.1 GHz 6-core i5, up to 3.8 GHz 8-core i7. Released August 4, 2020.
Can be this model 2020 be upgraded to i9?
Model Name: iMac
  • Model Identifier: iMac20,1
  • Processor Name: 8-Core Intel Core i7
  • Processor Speed: 3,8 GHz
  • Number of Processors: 1
  • Total Number of Cores: 8
  • L2 Cache (per Core): 256 KB
  • L3 Cache: 16 MB
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
27条评论
Here's your systems series: iMac20,1
these are the possible CPU's your system can support.
完成的
Is possible upgrade with I9 10900KF??
thanks
完成的
The 3.6 GHz Core i9 (I9-10910) is the best CPU Apple used in this series.
Core i9-10910 Processor
Core i9-10900KF Processor
As you can see you loose the UHD Graphics 630 which Apple uses at startup, and you wont get the higher clocking. Best to stick with what Apple used.
完成的
Hi Dan
So you confirm that I can install the 10900KF? By not having integrated graphics it will heat up less.
Thanks
完成的
@eullin - Cutting off your right leg will use less blood, but you can't run very well. This is the same issue as you'll loose the startup services without the IG services.
I personally wouldn't do it. Heat is really not an issue if you use a good thermal monitoring app like TG Pro.
I would also make sure the vents are not blocked and clean out the dust yearly.
完成的
显示更多的22条评论
添加一条评论
3个答案
最有帮助的答案
So while it’s possible its not an easy process!
We don’t have a guide for your exact system but this one is very close to the same procedure to get the logic board out iMac Intel 27" Retina 5K Display Logic Board Replacement Keep in mind you need to use the correct tools and technique to get the display off otherwise you risk damaging it!
After taking the logic board out getting the current CPU out is not that hard but putting the new one in as a real pain! Many people struggle getting the CPU properly placed in the socket and/or damage the logic board socket in the process.
Of the three systems I got in which someone had attempted to install a replacement CPU in this design series two had damaged to logic board to the point I couldn’t save it.
Also be careful on what TIM you use and don’t over do it! It takes very little to do the job.
这个答案有帮助吗?
得分 3
3条评论:
wow that is a lot of work, seems like you would be better off just replacing with a mobo that can handle it.
完成的
@spacecadet420 - Sure replacing the logic board with the i9 installed already also works.
完成的
What is the best i9 chip ican upgrade for imac 5k 27” 2019 ( 3ghz 6core intel i5?
完成的
添加一条评论
I upgrade mine to the i9 10850K everything's appears to be working fine.
I'm worried that the power supply won’t last for a long time.
这个答案有帮助吗?
得分 1
6条评论:
Your lucky! Both have the same TDP and are based on the same microcode (Comet Lake).
Intel i9-10910 CPU
Intel Core i9-10850K
完成的
macOS Monterey no issues with the upgradet iMac so far (10850K)
完成的
10850K not work, i was try this. iMac 2020 and 3.3Ghz i5 - 10600. When I replaced it, only 2 LEDs were on instead of 5. This indicates that the graphics did not start at all
完成的
@rsxkct3wpy40hp1 - are you sure you mounted the chip properly? These are hard to seat into the socket and if you’re no careful you can damage the chip as well as the socket.
Be aware unless you have the needed cable extensions you can’t test the system by the onboard diagnostic LEDs. Often the pulling on the cables damages the logic boards data cable connector and/or the cable it’s self.
I know of a few people who have swapped out the chip so it can be done.
完成的
may I know what your imac's Model Identifier is? iMac20,1, or iMac20,2? cheers.
完成的
显示更多的1条评论
添加一条评论
I usually wouldn't answer the question, suspecting there would be some "gotcha" trick answer, but I would reply with a qualified yes. Apple is profitting handsomely from their proprietary technology and configurations, so what I would say is yes, if you are willing to replace most of what's inside of the computer.
YOU MAY BE IN IN LUCK
This was the final year of production of the Intel iMac and lat this point all the bugs and flaw in the design had been worked out. If you can find someone (like myself) who is about to convert their 2020 iMacto be a 5k display only. That modification requires removing all the internal computer components, including CPU, Memory and storage, and replacingthem with a new aftermarket hardware display board. I ordered my iMac custom, so it came configured with a 10-core i9 and 1TB SSD storage. I upgraded the RAM to 128GB.
IT'S ALL AVAILABLE
Once I complete my conversionI don't have plans as to what to do with components, and if someone else were interested in instaling these components in their iMac, I am open to discussinga a fair sales price for the package. I do not want the components to wind up going to a shady eWaste site and a solution that requires the least cost to our precious habitat we live is the one I prefer.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
djleba 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 26
过去 30 天: 109
总计 7,959
