跳转到主内容
Repair and disassembly information for Samsung's flagship S20 Android smartphone, released in March of 2020.
49 个问题 查看全部
Can I get a professional to fix my charging port?
I've called a few places now, and they all say it can't be fixed because it's sodered in. But the guide on this site shows how to remove the whole daughterboard. I don't want to take the risk myself, since I could easily screw it up and end up with an even more broken phone. Right now, I can charge it with the wireless charger, so it's not desperate, but I'd like to find a way to fix it properly.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @nezeltha ,
Replacing the daughterboard is the safer option (easier and possibly cheaper as well) rather than unsoldering a USB-C connector and soldering in a new one. The daughterboard has to be removed anyway so that there is good access to the connector.
Given the cost of a replacement board (supplier example only to show cost) it’s understandable why board replacement is the preferred option.
Unlike micro USB 2.0 connectors which have only 5 pins, USB-C connectors have 24 pins which makes it that much harder to replace.
Here’s a link to the iFixit Repair Pros listing. The professional repairers who are shown have all agreed to abide by the Repair technician’s creed. Enter your location in the search repair pros search box to hopefully find a repairer close to you that you can contact
这个答案有帮助吗?
得分 1
2条评论:
Is there a way to find local people in the repair pros listing?
完成的
@nezeltha
Did you type your location i.e. city or town will do, in the search box on the repair pros page as suggested?
If none show up then you may just have to search online for repairers in your location and check their reviews as to whether they're any good or not.
完成的
添加一条评论
添加你的答案
Brian Emerson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 10
总计 146
