跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
Can I fix a broken connector housing/mount?
I was trying add new thermal paste and when I was removing the logic board, I accidentally cracked and then broke off one of the connectivity housing that (I think) goes to the disc drive. The cable/wire seems fine. It’s the mount that held the red cable
that is broken. Is this part replaceable/repairable? I’m having trouble finding a part that would match. Any ideas? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It’s the socket for the left speaker similar to the fan socket. It can be soldered back to the board if you find the part. You can harvest it on a Macbook donor board or buy it on eBay. Any tech can solder back the socket for cheap, only six micro solder to do on this part. Don’t try to glue it on the board, the 4 front pins must make a good contact to the pads and only solder can be used in this case.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
MyMusic Nakamura 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 28
