跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Why can't I hear incoming calls (except on speaker or earpiece)?
I have a iphone 6s Plus, earpiece and speaker work, but I cannot hear incoming calls unless through the earpiece or speaker. Which of the phone microphones need to be replaced?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
I may be a bit confused here but if not through the earpiece speaker or the loudspeaker, where do you want the sound to come from??
完成的
When you're saying microphone, do you mean that nobody is able to hear your audio on a call or do you mean the speaker that makes sounds. I believe you mean that your loudspeaker works fine and audio can come through headphones, but won't work on the earpiece speaker at the top of the phone when on a call?
完成的
Yes, thank you, that is correct, Liam.
完成的
添加一条评论
2个答案
When I used the word ‘earpiece’ I meant for the ‘headphone’ To clarify , I under stand there are three microphones: One for ear, one for speaker, one for headphone. The headphone and speaker work. The one for ear does not.
Update (05/04/2021)
I will give your suggestion a shot.
这个答案有帮助吗?
得分 0
添加一条评论
Try replacing just the earpiece speaker up the top by the front camera assembly, using this part below;
iPhone 6s Plus Earpiece Speaker
If replacing this doesn’t resolve the sound issue you may need to replace the entire front camera assembly as it transmits the sound data from the logic board to the earpiece speaker, but attempt the easier and cheaper fix first :)
Replace an earpiece speaker compatible with the iPhone 6s Plus model #A1634, A1687, A1699. Fix problems with phone call audio.图片
产品
$19.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Avrohom Teichman 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 172
