跳转到主内容
2020年4月宣布和发布的第二代iPhone SE的维修和拆卸信息。
239 个问题 查看全部
问题已关闭
iPhone shuts down every 2-3min after deleting microphone
I want to be fully anonymous so i cut my microphones out off my iphone.
now when i reboot it it shuts down every 2-3 min. in the analytics log it says: panic full en then it says: "(1 monitored services unresponsive): checkin with service: thermalmonitord returned not alive with context:\nis_alive_func returned unhealthy : current 3fe3bfffffffffff, mask 1ffffffffffff, expected 1ffffffffffff. Missing sensor(s): mic1 \nno successful checkins since wake (120 seconds ago)", a new dock connector will probably fix it but how do i delete my microphones without my phone tripping like that?
the second time i tried i maked a little hole in the mic with a very fine knife so i was sure the microphone was broken but still plugged in but the same error popped up and the iphone is rebooting again.
i know i can disable my mic in settings but im still dont trust it when doing that. i hope someone haves a answer for this.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
hello Newbie911
are you kidding us? You damaged your microphone so that no one would eavesdrop on you? So how do you make phone calls? More important question: which microphone did you destroy? after all, the other two are still working. The microphones can be turned off by hardware in the settings or simply unplug the entire tape - a permanent solution. Write something more, it interested me very much.
PS, by writing here, you leave a trace in the form of an electronic signature of your computer, network router, Internet provider, etc. Why the whole thing with hiding, if less than five minutes is enough to track you down to 1m2
这个答案有帮助吗?
得分 2
4条评论:
I dont make any phone calls ever en dont give anyone my phone number. and yes i did, I deleted the 2 lower microphones, stung the one in the back and stung the one at the front cam cable. but the error came only from mic1 and i dont know why exactly. I allready have turned off every microphone setting i can find but i still dont trust it. Do you think that taping the microphone will be enough? i am interested i a permanent solution for this and any ideas are welcome. and i thought browsing with vpn and tor was good enough. i didnt see any cookies or something so if you have good reccommendations for that it will be welcome also.
完成的
probably a sensor is also attached to this tape. Write what phone it is, I'll try to find a solution asap.
I mean, has your SE2020 been used by someone before, has everything worked or has adventures (like an earlier repair related to ... etc) ?
完成的
@tojaert It's a Iphone SE 2020 model. I have repaired the lightning connector and the phone is working fine again. But i still want the mics out haha. i have put some little pieces of tape on both mics but i can still hear everything when i listen in microphone app. i hope u can find something :)
完成的
hello again,
I think I have something interesting. Write an email, the address can be found in "view profile/about" tab. Vultures are already circling.
完成的
添加一条评论
Fixing phones are easy, fixing paranoia on the other hand is way off topic.
这个答案有帮助吗?
得分 1
4条评论:
It's an iphone related question so i dont see the problem? and maybe there is a good reason, just keep your prejudices plz.
完成的
So I’m the one with prejudices? Funny how people don’t see their own prejudices.
完成的
what?? Xd I dont understand why u answering.. it isnt a answer on my question, u just talks to talk i guess.
完成的
@newbie911 This is as much help as you can get from me, fix the bigger problem first.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 1,031
