How to recover deleted photos videos from samsung galaxy s21?
Do you know how to recover deleted photos videos from samsung galaxy s21? I lost some videos and photos from my S21 and want to restore them.
If you have backed up your videos using some cloud services like Samsung Cloud, Dropbox, etc. then you can directly get your deleted videos back by extracting them from the backup.
If the above way fail to help you out, there’s the last choice for you to get deleted videos and photos back. MobiKin Doctor for Android is a 100% safe and powerful Android data recovery tool that is widely accepted as the best tool for Samsung users to retrieve deleted or lost files including photos videos.
这个答案有帮助吗?
Check your Google Drive - maybe you have a backup there. Similarly, check Smart Switch for backup.
If you use Google Photos App, then check the trash section of the app.
If you do not have any backup, anywhere else, then in such condition, you must try third-party data recovery sofwtare.
Check this post for the better solutions - Recover Deleted Data From Samsung Galaxy S21/S21 Plus/S21 Ultra
这个答案有帮助吗?
Hope you have solved your problem since it has been two years. For the one who still has the same problem, here are some steps to help you recover deleted photos and videos from your Samsung Galaxy S21:
Check the Trash or Recently Deleted Folder:
Samsung devices have a built-in feature called the "Trash" or "Recently Deleted" folder in the Gallery app. Deleted photos and videos are often moved to this folder for a specific period before being permanently deleted. To check:
1. Open the Gallery app on your Samsung Galaxy S21.
2. Look for a "Trash" or "Recently Deleted" folder within the app.
3. Open the folder, and you may find your deleted photos and videos there.
4. Select the files you want to recover, and tap the "Restore" option.
Use Samsung Cloud:
If you have Samsung Cloud backup enabled, your deleted photos and videos may be recoverable if they were backed up before deletion. Here's how to check:
1. Go to "Settings" on your Samsung Galaxy S21.
2. Scroll down and tap "Accounts and backup."
3. Tap "Samsung Cloud."
4. Select "Restore data" and choose the files you want to restore.
Google Photos:
If you use Google Photos to back up your media, deleted photos and videos may be recoverable from the cloud. Follow these steps:
1. Open the Google Photos app on your device.
2. Tap the three horizontal lines (menu) in the upper-left corner.
3. Select "Trash" from the menu.
4. Find the deleted photos and videos, select them, and tap "Restore."
Use a Data Recovery Software (PC/Mac):
If the above methods do not work, you can use data recovery software on a computer. These tools can help recover deleted files from your Samsung Galaxy S21's storage. Here are the steps:
1. Download and install reputable data recovery software like Coolmuster Lab.Fone for Android, MobiKin Doctor for Android, or Dr.fone, etc. on your computer. Connect your Samsung Galaxy S21 to a computer using a USB cable.
2. Follow the software's instructions to scan your device for deleted photos and videos.
3. Once the scan is complete, preview the recovered files and select the ones you want to recover.
4. Click the "Recover" button to save the selected files to your computer.
Contact Professional Data Recovery Services:
If none of the above methods work, or if your data is extremely important, consider contacting professional data recovery services. These specialists have the expertise and tools to recover data from Android devices, including your Samsung Galaxy S21.
Remember to regularly back up your data to prevent data loss in the future. You can use cloud services, external storage, or Samsung's built-in backup options to keep your data safe.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 45
总计 1,064
3条评论
This post is helpgul : https://www.smart-iphone-recovery.com/an..., it shares a way to restore data from S21
由 Bodsmient 完成的
@Bodsmient thanks for your help. it worked.
由 Jesson Liu 完成的
This one didn't work to pull up the deleted photo. Is doing a root and deep scan my only option?
由 Aaron Rate 完成的
