跳转到主内容
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
205 个问题 查看全部
Well I did something stupid.
I did something stupid out of curiosity. I took a 9 volt battery pack and tried to power on the system and charge it using the leads on the console. Now it won’t turn on (as expected). Is there any way i can fix it now or did I shoot myself in the foot?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Board repair is the kind of things that if you need to ask, you can’t fix it.
So it’s more like shot yourself in the head instead of the foot.
这个答案有帮助吗?
得分 1
2条评论:
I’m trying to ask about Board Repair because it’s something I want to learn. Are there any good resources?
完成的
@el_the_great There are plenty, but don’t start with your actual broken board, always start with cheap practice projects.
This is what I meant if you need to ask, you can’t do it, at least for now.
完成的
添加一条评论
添加你的答案
Heorge Valentine 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 37
