跳转到主内容
The Samsung Galaxy A10s is an Android smartphone developed by Samsung Electronics, and was released in March of 2019.
a10s will not turn on
samsung a10s will not turn on and will not changer too
回答此问题 我也有这个问题
这是一个好问题吗?
得分 16
3条评论
Hello,
Did anything happen to cause the error?
完成的
What was happening before it did this? Did it get hot? Make any noise? This post is not descriptive at all.
完成的
my phone will not turn on with the on button
完成的
添加一条评论
2个答案
最有帮助的答案
Remove the back and disconnect the battery reconnect the battery and plug the charger in.
这个答案有帮助吗?
得分 2
添加一条评论
hello as i owner of this phone i have dealt with the same problem if i press the power button nothing happens i can still unlocked with my fingerprints it will unlock. If your phone is power off and you want to turn it on get your laptop,pc,mac and press the volume up and down button and plug it in the pc when it turns on press the volume down button it will restart and herre you are fixed i hope i have helped you and thank you and thi problem is caused by watter getting in the power button it happens
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
richard hartley 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 21
总计 1,674
