The HP Spectre x360 13 -ac023dx is a compact laptop which is light, powerful, and has smart security features.
Kevin Diaz @kdd415
声誉积分: 1
发帖于: 2021年4月24日
My laptop has no problems when I start it up, but if I close the laptop for a while and open the computer it says no bootable device.
这是一个好问题吗?
3条评论:
Curious. What happens if you shut it down from Windows and close the "lid" and then open it and press power button to turn on?
由 mike 完成的 2021年4月24日
I close the lid while the computer is on. Later I go and open and notice the computer is really hot and the screen says no bootable device.
由 Kevin Diaz 完成的 2021年4月24日
@kdd415
Hi Kevin,
I understand that but try what I suggested above. Is it still hot later on?
You may have some process still running after you shut the "lid" which is excessively accessing your hard drive causing it to overheat.
If it is cool after proper shutting down then you will know this is the case. Try it.
Camellia Wu @camelliawu
声誉积分: 13
发帖于: 2021年4月25日
Please take a look at this post to find a solution.
https://www.partitionwizard.com/partitio...
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 9
总计 158
由 mike 完成的
由 Kevin Diaz 完成的
@kdd415
Hi Kevin,
由 mike 完成的
