跳转到主内容
Apple的9月20日发布的Apple主流2019 iPhone带有6.1英寸LCD触摸屏,双摄像头和六种可用颜色。iPhoneXR的后继产品。
476 个问题 查看全部
Why will my phone not charge past 5%?
For the past 3 days, my phone has not been able to charge past 5%. Although showing the charge symbol, it doesn’t charge properly.
Here is some additional info:
•Software version: 14.4.2
•iPhone 11
•Have had the phone for half a year
•It fails to charge past 5%, even when using different chargers/blocks/power points
•When not on charge, it quickly loses battery
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
If your device is only 6 months old you have still waranty, then i would go to a Apple store for the fix.
完成的
添加一条评论
1个答案
已选择的解决方案
The most likely cause would be a failing battery. Even though you have only had it for six months the battery can still fail and can produce the symptoms you are facing.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Caitlin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 212
