iPhone X Screen Replaced - Black Screen - Can't Hard Reset
Hi,
I replaced the screen on my iPhone X. I checked the connections and the new screen worked and it powered on. After I added the metal casing over the connections and cable, I can not power the phone back on. The screen is 100% black. When trying to hard reset a loud piercing alarm-type sound gives a short burst, but nothing past that. I took the metal casing off and re-checked the cables.
What could I have possibly broken?
iTunes does not recognize phone as well.
You have put back the screws at the right spot, there are long and short screws.
由 Leslie Leslie 完成的
I am certain there are some in the wrong spot, but everything things seems secure and connected securely. Would a wrong size screw used prevent the phone from turning on? The screen was tested on another phone and it works fine. I am paying someone to test the circuits now. I’m stumped.
由 Jessica 完成的
@legtysgirl could be long screw damage to the logic board.
由 daniel 完成的
Oh, man! That makes so much sense ?♀️
...hopefully not.
Thank you for explaining
由 Jessica 完成的
@tech_ni Yes, you are right. Damaged Logic Board :I
由 Jessica 完成的
显示更多的1条评论
