跳转到主内容
Repair guides and support for electric and gas-powered high-pressure sprayers sometimes referred to as power washers.
38 个问题 查看全部
Name this part: Craftsman electric pressure washer model 99016
Massive water leak and loss of pressure on Craftsman electric pressure washer model 99016. Teardown revealed a break in this water line component (should be one piece instead of two), measures about 3” x 4”. Unable to find a parts diagram for the internal workings; the diagram in the manual only contains external components like nozzles and detergent tanks. Purchased the unit on 6/8/2017 prior to the closure of our local Sears, not that long ago in my opinion, yet Sears Parts Direct cannot locate this model number. Without knowing the part number or even what to call it, our conversation went nowhere. Somewhere in the world there is box of these parts sitting on a shelf. Please help me find them!
In the event my search is futile, any advice on a workaround? JB Weld is the only trick on my mind at the moment.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
What was it connected to?
完成的
The threaded end connects to the wand hose. The broken end connects to the pump.
完成的
I am having the same difficulty. My problem is a carbon copy of yours……. Somebody help us!!!!!!!
完成的
添加一条评论
1个答案
已选择的解决方案
Can't find anything about this particular part or even this washer. Highly recommend against jb weld. Especially on a high pressure part. I would advise checking with local machinist/welders and see if it can be repaired that way. Will handle the pressure better.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Regina Polok 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 46
总计 502
