跳转到主内容
加入维修社区 - 创建账户
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
Digital Output - Headphone Workaround
How do I get the Headphone/Digital Output to play analog? Is there a driver one can download or a cable that could convert this digital signal to analog? Not sure how that works specifically. And I don’t want to waste time and money on accessories that won’t solve the problem.
The speakers and everything works just fine and there is no issue with the headphone jack being stuck. That seems to be the only thing I can find when I search for resolutions, and I just want to say that isn’t the issue. I have bluetooth headphones, but there is a lag with the older bluetooth tech. Working in audio editing, this can be frustrating. Thank you very much!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Your headphone jack is dual use! You can use a standard analog mini plug headphone or connection to a wired speaker.
You can also use a digital TOSlink to Mini TOSlink Digital Optical S/PDIF Audio Cable like this one:
So depending on what your needs are analog or digital use the correct cable.
Update (04/19/2021)
@AJ Cronk - There's no drivers needed. The macOS has what’s needed.
Sadly, it sounds like your jack is damaged. There’s a lot going in inside the jack! The analog contacts are also switches so the audio is sent to the speakers or to the headphones as you can see here.
这个答案有帮助吗?
得分 0
1条评论:
Hello! Thank you for the quick answer. Unfortunately, when I plug regular headphones in, the control only says “digital output” and there is no sound to my headphones. Is there a driver missing that I need to install?
完成的
添加一条评论
添加你的答案
AJ Cronk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 73
