跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
4S Battery Life
Can one get a longer life battery?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
This is a problem Apple is working on. At this time they are trying to determine if the problem is in the hardware or the software. Be patient--some solution should be out soon.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
rj713 is correct, but if you want to save some battery life while Apple tries to figure this out, here are a few battery saving tips:
- Go to Settings>Location services. Then turn off anything that you don't want to constantly know your location.
- Go to Settings>Mail. Then turn off "Fetch New Data." This will make it so that you have to tap on the Mail icon to check your mail, but will save your battery life considerably.
- Go to Settings>Brightness. Then turn it down as far as you can deal with. Turn auto-brightness on.
- When you aren't using WiFi, go to Settings>Wi-Fi. Then turn it to "off."
Each of these will give you some extra battery life. I did them to my phone and have noticed considerably longer life, especially from the first two tips.
Hope this helps!
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Miguel Moreno 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 967
