跳转到主内容
加入维修社区 - 创建账户
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer won't start-No F01 Code
The Dryer does not have power going to it. Checked outlet, it has power so itisn’t a power outlet issue. Fuses are all in good shape. Repairman suggested control panel issue, but couldn’t replace due to his company not carrying the panels.
In all other cases for this dryer, I have seen changing the control panel as a solution to the F01 error code, not for a dryer that won’t start, period. Does this seem like a solution, or does this seem like the dryer is just done. I just don’t want to pay 150 for a control panel if it likely won’t do the trick!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi,
What is the model number of the dryer?
完成的
添加一条评论
1个答案
If you have had a power outage or surge recently this is most likely the answer to the problem.
If this is the case the answer is to buy the new control panel.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jillian Pastick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 17
总计 1,039
