跳转到主内容
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
Internal SSD not detected by MBA Mid 2011
I was given an old MacBook Air 2011 to move over files from that MacBook to a newer one. After I completed the process, I decided to update the laptop from Sierra to High Sierra. I let it download the update and I went to fix some stuff, but when I came back the laptop had turned off. I tried booting it and I was hit with a white screen, and a minute later a flashing folder icon was shown. I have tried all of this trying to fix the issue:
Booting into safe mode (DIDN’T WORK)
NVRAM reset (DIDN’T WORK)
SMC reset (DIDN’T WORK)
Apple Hardware Test (NO ERRORS FOUND)
Recovery Mode (Couldn’t use Time Machine or OS reinstall due to the storage device not being recognized, and Disk Utility only shows “disk0” and “Mac OS X Base System”)
I really don’t know what to do at this point, that’s why I am asking here for help. I am a total newbie with Macs and I apologize if my writing is hard to understand, english isn’t my main language.
Any help is appreciated! :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Are you able to see the drive when you boot up with the Option (⌥) key?
Reference: Mac startup key combinations
这个答案有帮助吗?
得分 1
11条评论:
I did that too but forgot to mention it, I am just prompted to choose network. No drives.
完成的
Setup an external bootable drive. You’ll need to boot under it
完成的
@danj is the internal ssd done?
完成的
@choonky - It might be and it might not! Until we check it no one knows.
完成的
I am pretty sure the drive is dead. I booted into recovery mode with cmd+r and i was booted into an old version of the recovery menu (os x lion) and as i mentioned in the post the (very outdated) disk utility showed only disk0 and Mac OS X Base System. I was thinking about it and thought that it maybe didnt recognize the file system. So i loaded the high sierra installer (last supported OS) onto a usb stick and tried disk utility again. This time, it shows the external usb (Install macOS High Sierra) and a disk image called ”OS X Base System”. The disk format is Mac OS Extended and is 2.01GB in size, with 1.29 GB used and 719,5MB free space. When running diskutil list i am shown the 16GB usb stick, the disk image i mentioned earlier and a ton of ”disk(number)” disk images ranging from the kilobytes to megabytes. In the installer, the only disk i am shown is the external usb stick. I hope this information lets you decide if the ssd is dead or not. Also, thank you so much for helping me!
完成的
显示更多的6条评论
添加一条评论
添加你的答案
Choonky 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 635
