跳转到主内容
2018年7月发布,15英寸 MacBook Pro,型号 A1990,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
How to open bottom plate?
Does anyone know how on earth i can get the rear clips on the backplate of a 2018 15" MacBook Pro to release? I was following this guide (2018年带 Touch Bar 的15寸 MacBook Pro 底壳更换) and I could do everything until it said to "Pull firmly to slide the lower case towards the front of the MacBook", I've tried doing so repeatedly and the clips just wont release. I don't want to pull any harder as I'm afraid of damaging something inside.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Make sure that you run the plastic pick around the front and the side of the laptop to release all the hinges on the side and then try to slide it forward. I think something is still catching on yours on either side.
完成的
添加一条评论
1个答案
Here’s the key!
So you need to lift the bottom edge using a set of plastic picks and a suction cup to lift the cover over the edge sliding the bottom cover down to clear the tabs and the snap catch.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
BlueCreeper512 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 409
