跳转到主内容
Samsung的旗舰手机,Galaxy S8,发布于2017年4月。
304 个问题 查看全部
Battery health is still show less after new battery replacement
If you see the screenshot that indicate that battery health is 83% after replacement of brand new replacement battery. Is that poor new battery or something else? How we can make 100% battery health ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
6条评论
Is the replacement battery a genuine replacement part from Samsung or a third party?
完成的
It is Third party not original one.
完成的
@irepairman If the rest of your device is functioning fine, then you may have just received a bad battery unfortunately. Are you able to try another battery in the device, preferably a new Samsung battery?
完成的
I put new battery but still it shows weak
完成的
I have the same issue with s10e I have tried 3 new batteries so far. Still I hav the issue .... any ideas
完成的
显示更多的1条评论
添加一条评论
3个答案
最有帮助的答案
This is because the battery cycle count has not been reset. In order to reset it, you either have to root your phone or have an authorized repair center like UBreakIFix to do it, which they charge $50~ to do so.
这个答案有帮助吗?
得分 1
添加一条评论
When you replaced it did you allow the battery to cycle fully a few times? Charge to full, discharge completely, then charge again. Do this a few times. When it dies, turn it on again and let die again. Do this until it fails to turn on (screen should just show battery is at 0%) once it does charge to fill, and let die again. When replacing lithium batteries from what I've experienced you have to cycle the battery to get it fully functional. Otherwise could be a bad battery.
这个答案有帮助吗?
得分 0
添加一条评论
Samsung think it will be better for them to make step against right to repair even when customer buy original OEM battery, do we really own our phones ?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
iRepairMan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 66
总计 2,650
