跳转到主内容
于 2014 年 10 月 16 日发布,型号为 A1347 和 EMC 2840。
Why am I not seeing SSD in Disk Utility after installing?
HI, I found a video on youtube about installing an SSD using an adapter that looked quite easy to install. But after doing this, I am not seeing the SSD in Disk Utility. He was installing it in the same Mac mini. I purchased this adapter. and purchased this SSD. I started up in recovery mode, and opened up DU, but only see the HD. Shouldn’t I see it at this point, in order to format it? I’m sure it snapped in fully, though I can recheck it again if that might be the issue. The SSD fit nicely inside the adapter. Did I purchase items NOT compatible?
Any help would be appreciated, Thanks!
Rebecca
edit:
Oddly, the links didn’t show. These are what I purchased:
Adapter: Sintech M.2 NGFF NVMe SSD Card for Upgrade Mac Mini Late 2014 Year A1347 MEG Series
SSD: Western Digital 1TB WD Blue SN550 NVMe Internal SSD - Gen3 x4 PCIe 8Gb/s, M.2 2280, 3D NAND, Up to 2,400 MB/s - WDS100T2B0C
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
What is the macOS you are system is using?
这个答案有帮助吗?
得分 1
3条评论:
That was it! I just finished updating to Big Sur and NOW I see it. Was just about to delete this question and saw your reply. Thank you!
完成的
Hello, did you install the Mac OS and After formatted?
完成的
Did you replace the main drive?
完成的
添加一条评论
添加你的答案
rebknell 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 344
