跳转到主内容
Charge is decreasing on charging
Power problem not chraging
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Chances are your charger is either dysfunctional or doesnt provide enough power to the tablet, try isolating whats going on. Try a different charger if it works you know the OG one is either broken or insufficient.
完成的
添加一条评论
1个答案
This is probably not an issue with the tablet itself, this is probably the charger you’re using. Try using the charger provided by the manufacturer or use a different cable/adapter.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Suvosree Ray 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 507
