3 monitor setup; 2 HD, 1 SD (WHY?)
Hello, I just got a 3 monitor docking station with 3 HDMI outputs. It connects to the Yoga with the USB-C. All connect, except 2 are able to display HD and 1 is not able to.
What could the problem be?
Thank you, Jeff
Update (04/09/2021)
Hopefully this picture uploads properly
Update (04/10/2021)
Here is the driver which was the latest to install. I will check the Intel site next.
Update (04/10/2021)
This is the new driver I will try to install.
Update (04/10/2021)
This is the error I get…
Hi @jkash76 ,
Is the non HD display always on the same HDMI output regardless of which monitor is connected to that outlet or is it always the same monitor regardless of which outlet it is connected to perhaps, you didn't say?
由 jayeff 完成的
Hello,
it seems it only allows for 2 HD and 1 SD. It’s not the monitor cause I can switch the outlet and the SD could show up on a different monitor.
由 Jeff Kash 完成的
@jkash76
What do the specs of the docking station say as I presume it converts USB-C to HDMI?
由 jayeff 完成的
This is the docking station.
USB-C 4K Triple Display Docking Station, Baseus... https://smile.amazon.com/dp/B082R5S1MP/r...
由 Jeff Kash 完成的
@jkash76
The specs say that it only supports 1080P if three HDMI displays are attached so if it doesn't then maybe the problem is with the docking station or the pc output resolution.
What resolution (frequency?) is the pc output . Just wondering if it has to be scaled back.
The specs show that with 2 monitors you only get 4K at 30Hz and not 60Hz
由 jayeff 完成的
显示更多的12条评论
