跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 个问题 查看全部
Why are there vertical blue lines and I cannot login
I have vertical blue lines on my monitor. When I restart I get the same thing and any text or graphics look blurry. This prevents me from logging on. I have tried rebooting using other modes explained online with no success. Any ideas on the issue?
Update (04/05/2021)
Is there a simple fix for a replacement part or is it time to just retire this computer? If it’s time for replacement, I’m totally fine (have backups from time machine) but before I get rid of it how do I best clean the computer of personal info before it gets recycled, since I cannot access any info right now?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Not good ;-{
Your GPU board has failed iMac Intel 27" EMC 2429 Radeon HD 6770M Graphics Card
iMac Intel 27" EMC 2429 Radeon HD 6770M Graphics Card图片
产品
$99.99
这个答案有帮助吗?
得分 0
5条评论:
完成的
@Chris Radcliffe - Some people have managed to cook the board to get a bit more live out of your system. Replacing it is getting hard as these board are no longer being made.
完成的
Thanks for the advice. I have seen some discussions on that but I think I’ll retire it. Is there a way to clean computer of personal info before I recycle?
完成的
@Chris Radcliffe - You should still be able to boot up in Target Disk Mode. See if you can you should see a FireWire or Thunderbolt Icon on your screen if you do then you should be able to connect your system to a second Mac to copy off your system and properly wipe down the drive so nothing is recoverable.
Reference: Understanding the Applications for Target Disk Mode
If that won't work then you can remove the drive and use a 3.5" SATA to USB case to hold your drive to then copy stuff off or even use your drive as a backup.
完成的
Great! Thanks again!
完成的
添加一条评论
添加你的答案
Chris Radcliffe 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 158
