跳转到主内容
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 个问题 查看全部
Black Screen after changing thermal paste
IMAC 2011 21.5 EMC 2428
It was working perfectly.  It was opened to change thermal paste.  Now it turns on but the screen goes black after a few seconds the fans accelerate.
The diagnostic LEDs light up the 4.
 Apparently there was no error in the assembly or damage to any cable or board.
 the machine had no problem with the video card before
 After reassembly, he presents this symptom.
 Only the thermal paste of the processor was changed.
The video card has not been tampered with.
 Do you have any tips or details that I may be missing?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
More often than not, you likely didn’t mount the CPU correctly. You’ll need to pop is off again to make sure the socket pins are not damaged and when you remount the heat sink make sure you slowly tighten the screws in a cross pattern like you do for changing a tire rim, tighten each screw in a star, or criss cross, pattern.
这个答案有帮助吗?
得分 2
2条评论:
the screws on this heatsink seem to be wrong, they don't seem to want to screw in the normal way. Before reading your comment, I took apart everything and retained the heatsink screws again, this time without tightening them too much. I reassembled everything and it worked again.
完成的
@friedericham - If you're set don't forget to accept the answer - Thanks!
完成的
添加一条评论
添加你的答案
friederich.maiochi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 267
