Rattle Under Engine at 25 mph
I have a rattle under my engine that starts at ~25 mph and disappears after accelerating to 35 mph.
I have a vehicle that does the same thing and it was just the idle of the motor making the exhaust slap against a piece of tin that kinda wraps around the muffler close to were the muffler bolts to the motor. Can also u a long rod as a stethoscope and put your ear to one end and touch the other end around the spot where you hear the noise. Do this while the vehicle is idleing. Please be careful and don't put it in a spot were something is turning or moving.
这个答案有帮助吗?
This happened on my 1996 F-150. The catalytic converter heat shield was loose. After a few attempts of refastening it, I used good old mechanics wire instead of bolts . . . no more rattling.
Finally was able to get under my truck, and the answer was spot on. Thanks for your advice.
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 16
总计 411
