跳转到主内容
4英寸屏幕;多种颜色可选;共发布三款型号;闪存容量:16、32及64GB
331 个问题 查看全部
Forcing an undercharged battery to charge?
I replaced the screen on my iPod touch 5, but when I went to test it, it got stuck on the charging screen and sometimes flashes the Apple logo. I checked with a multimeter and the battery is at 2.69v. I left it overnight to no avail. Is there any way to force the battery to charge without replacing/desoldering the battery?
Update: I’ve gotten it to 2.9v leaving it on charge for a few more hours and making sure it was the battery flat screen, I’ll try leaving it overnight again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
try this
iPod Touch 5th Gen won't boot passed the APPLE screen
also on youtube northridgefix and louis rossman both repair apple products REGULARLY. you might be able to find a video with your problem also.
这个答案有帮助吗?
得分 0
3条评论:
It's actually not even turning on when not on the charger. In that thread, it seems like the battery is charging and working normally.
完成的
if its not turning on when not on the charger that would indicate the batter circuit doesn't know the battery is there to draw power.
id say if you haven't already:
check connections be sure to look for lifted contacts or bent pins.
look for corrosion on the board, typically around the chips and resistors.
make sure there aren't and SMD components that have been knocked loose \ off the board.
the SMDs can be VERY easy to brush over and pop one lose
完成的
@logixal I check with the multimeter and it is 2.9v, it's probably not enough to even show the low power screen
完成的
添加一条评论
添加你的答案
TheYootz Media Group 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 5
总计 175
