跳转到主内容
Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
Replacement battery not recognized, not OEM specs
On battery install, warning about not recognizing battery. I turned off notification in BIOS. It registered 60%, I drained for calibration, now won't work without adapter plugged in and reads battery as 0%. Shuts down when adapter unplugged.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
where did you get the battery from? I wonder if Dell serialized the battery, essentially tying it to that specific machine...
完成的
I got mine from I fix it and same problem. Warning message on startup that it is not a Dell battery and it refuses to charge it ?
完成的
添加一条评论
1个答案
Dell has stopped supplying these batteries, and my bios tells me the battery is not recognized. I purchased from IFIXIT
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Reggie Stecher 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 376
