跳转到主内容
Guides and repair information for Neato robotic vacuum cleaners.
36 个问题 查看全部
D85 Botvac: clunking noise while operating.
D85 Botvac is working fine, but now has a loud knocking/clunking sound when maneuvering. It is intermittent. I service clean the brush and bearings almost every run. I have tightened up the wheel hubs, so that is not the issue. At a loss.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
So the clunking turned out to be the brush motor becoming loose from the brush gearbox.
I removed the gearbox from the D85 and put blue thread-locker on the motor mount screws. I also added a thin nylon washer between the main transmission gear and the gearbox.
Everything is perfecto now.
这个答案有帮助吗?
得分 0
1条评论:
where is the gear box
完成的
添加一条评论
添加你的答案
Mike 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 203
