跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly guides for Kenmore Microwaves.
microwave fuse access problem
how do I access the fuse on a kenmore model 790.80353310 microwave
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @capncluster1 ,
Here’s an image showing the location of the fuse in your microwave oven.
(click on image to enlarge for better viewing)
There is always a reason why a fuse has blown so the reason for this will have to be found as you may find that if the circuit is not tested as to why this may have happened that when the fuse is replaced it will blow again.
It may be faulty or loose door interlock switches, a faulty HV transformer or perhaps a wiring breakdown. These are just some of the more obvious things to check as it may be something else entirely.
Here’s a link to the wiring diagram which may help.
Be safety aware when working inside a microwave oven. The HV capacitor can store >6000V DC for months, even if the power has been disconnected for this length of time. This amount of voltage can seriously injure you. The HV capacitor needs to be correctly discharged, as soon as it can be accessed after the cover from the oven has been removed and before any further work is done inside the oven. If you don’t know what you’re doing, then don’t do it! It’s not worth it.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
John Ehlke 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 24
总计 1,255
