跳转到主内容
The Sony Cyber-shot DSC-HX80 is one of the world's smallest compact digital camera with a 30x zoom lens. It was released in 2016 by electronics company Sony.
5 个问题 查看全部
What do you do when you have accidentally torn a tiny wire ribbon?
Along with loosening all of the other walls, I removed the left side panel (under the viewfinder) and a little yellow wire ribbon came out with it. I can’t even find the other end of the tear inside the camera. The tear occurs just after a right-angle bend in the cable. Also, I can’t determine how to detach the main golden wire ribbon from the lens (I’m attempting a lens replacement), despite removing several screws on a large, circular silver plate. The walls are not pulling apart very far in order to give me proper access. I don’t want to force it to the point of breaking something else.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
take a couple pictures, that would help point you in the right direction with this tear down. if its a ribbon cable that is actually ripped.
this site seems to have a couple ribbon cables as a replacement.
https://sony.encompass.com/item/10344184...
https://sony.encompass.com/item/10333301...
https://sony.encompass.com/item/10344257...
https://sony.encompass.com/item/10318414...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eric Torres 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 271
