跳转到主内容
许多Windows平板电脑的维修指南和拆卸信息,来自各种制造商。
Why is my Surface Pro 5 not powering on
surface pro 1796 (5) when powering up I get the windows splash screen for about 2 sec. then it powers off. Tried to do the reload but it won’t work. Any help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
You can follow this article, hope will fix Surface Pro Won't Turn On? Try these fixes -https://appuals.com/surface-pro-wont-tur...
完成的
添加一条评论
2个答案
已选择的解决方案
pull this from : https://www.lovemysurface.net/your-sufac....
our Surface Won’t Start, Method 1:
  1. Make sure that the Power Supply is attached to the device.
  2. Press and hold the Power button for 10 seconds.
  3. Repeatedly press and hold the Power button for 1/2 second before letting go (on/off on/off on/off).
  4. Wait a few seconds to see if the Surface begins running and screen turns on.
  5. If it does not, repeat the process.
This is the preferred method but it still did not start our Surface RT.
Your Surface Won’t Start, Method 2:
Important: Microsoft says to NOT use this process on a Surface RT or Surface 2. But obviously our Surface RT already seemed dead, so we were willing to give it a shot.
  1. Always make sure the Surface is turned off first –  not a problem in our case.
  2. Press and hold Volume Up (on the left side) and the Power button at the same time for at least 15 seconds. [You may see the screen flash the Surface logo but continue to hold for 15 seconds.]
  3. Release both buttons and wait 15 more seconds.
  4. Turn on the Surface as usual.
This method worked for us! But as we said, we didn’t have anything to lose. Microsoft says it’s a big NO-NO for the RTs. So, do Method 2 at your own risk.
And that is how you do a hard reset, if your Surface won’t turn on.
这个答案有帮助吗?
得分 1
4条评论:
Neither worked for me. I even tried the reload operation that Microsoft suggested. Thank you
完成的
did any of the other troubleshooting work?
完成的
If you are using a surface docking station, disconnect it from the Surface and use the regular power adapter. I have experienced issues where multiple docking stations on the same Surface device will have occasional issues, and they resolve after I use the regular power adapter to charge it back up. Afterwards, I continue to use the docking station fine for many more months until it happens again.
完成的
I confirm that using the regular charger, not a docking station, solved the problem. Battery was completely discharged, and the dock station would not charge the unit. Regular charger did.
完成的
添加一条评论
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kurt Lewis 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 11
过去 30 天: 78
总计 5,003
