跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
SOLVED: iMac powers on with LCD disconnected
Have a 27” Mid 2011 iMac in for repair.
Customer asked to have it pimped out with an upgraded graphics card, RAM, SSDs etc.
Did the work and put it together. Powered it up and was working fine. Issue is that it will give a short fan spin with one LED lit and not start unless the power has been unplugged for a number of hours. I reduced the iMac down to minimal config (everything non essential disconnected) and found that it will power on fine with the LCD disconnected.
I swapped the LCD assembly and PSU with known good ones and this made no difference being the most likely parts.
I have also swapped;
Logic Board,
Graphics Card (Brand New like the one I one I originally installed)
RAM
Backlight Board
Wifi card
Each of the swapped parts are known to be working fine and have been tested in another iMac. The graphics cards are brand new from Dell and have been flashed by myself for iMac compatibility. (I have installed 25 of these cards without issue)
Whats the next logical step forward on this repair?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
UPDATE:
DOA: graphics card was to blame.
Replaced it. Have flashed back the original Dell firmware to the old (brand new) one and have logged and RMA on it.
Mac working perfectly now except for the backlight dropping out. Will replace the 4 capacitors on the back of the backlight driver board to solve this issue.
Case closed
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Allen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 67
