跳转到主内容
The Sony Cyber-shot DSC-HX400V is a hyperzoom bridge digital camera that features a 20.4-megapixel Exmor CMOS sensor and 100-times digital zoom.
Menu button appears stuck
The upwards button on the menu wheel (the one that says DISP) Is stuck pressed down, so it always scrolls up. And the button for the flash doesn't react at all
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
did u spill anything on it? if so you should be able to drip some 90% alcohol in there and cycle the button a bunch to try and free it up. be sure if you do this to unplug the batter and let it sit for a minute then do the alcohol. and then take some canned air to blow it out and let it sit for a while to let the alcohol evaporate out to keep it from shorting anything out.
if nothing was spilled in there it might have just given out and will need to be replaced.
if its warrantied still take it in. if not then youll have to take the hit to the wallet.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Noël Wendel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 192
