跳转到主内容
Device repair and troubleshooting for the Dell Inspiron 15 inch laptop computer with model number 3567.
14 个问题 查看全部
My Laptop randomly freezes/hangs
My laptop was working perfectly but one day it started freezing randomly , keyboard and mouse not working , I had to hard reset and again the same thing. In addition , besides the freezing that still happens, more errors occur.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi:
If your laptop is old enough to have removable ram, I’d remove one module at a time (if there are two). If you have a known good module, you can swap that in. Bad ram can create weird symptoms, and it’s one of the easiest checks you can perform. I would do this first.
If your ram’s good, it’s just possible your hdd is going bad. This is harder to diagnose and fix. My younger sister’s 2019 Macbook just had its ssd fail, so it does happen on occasion. Unfortunately, newer Macbooks have everything hardwired to the logic board, so the entire board has to be replaced. If your laptop is older, you may be able boot from your dvd drive and run some tests that are more thorough than Apple diagnostics. And it is possible to replace the hard drive with care and diligence.
One other possibility, again, fairly hard to do, is to re-apply thermal paste to your CPU. The paste can get hard with heat and age. Usually as it fails though, it will throttle your speeds down to prevent damage. So, less likely than the others to create the symptoms you’re experiencing.
Good luck!
这个答案有帮助吗?
得分 0
1条评论:
Hi @dschind,
You may not have noticed but she has a Dell Inspiron 15 3567 which is, as far as I know, not a MAC. Also defective hard drives are actually quite easy to test. Just run one of the many freeware testing programs, such as "Disk Doctor". Hard drives actually have built in testing capability with "Smart" which can be read.
Here's how to check it from Windows:
https://www.windowscentral.com/how-check...
完成的
添加一条评论
添加你的答案
Chris Panatsias 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 429
