跳转到主内容
加入维修社区 - 创建账户
修理您汽车上的喇叭 音响 CD唱机 插座
The Rear and Sub pre-amp has nothing.
I have a allwinner p3_t1 (p3-T1)
eng/test-keys. 9 inch Android Radio.
all 4 high speaker outputs work fine. The front pre-amp work fine. But.. The Rear and Sub pre-amp has nothing. any help would be very appreciated. Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Those Android radios can be fickle. There are a lot of different models using the same board that have different features enabled or disabled. I'm not familiar with the "P3-T1", but it looks like the common T3-P1 defaults to a single pair of L/R preamp outputs plus a single sub output. If your wiring harness has separate front and rear preamp outputs then it might not be the correct wiring harness for that particular model of radio (or the harness simply has extra RCA jacks that cannot be used). Check with the supplier of the radio and look around online for other people using the T3. If you think the wiring harness is correct, then check the radio's settings and menus to see if there is anything that would turn outputs on or off. But my guess is the radio has only L, R, and Sub outputs and the harness has extra unusable jacks. Also be aware those wiring harnesses are very delicate so one or more RCA jacks might have become disconnected at the Molex.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
brodyfisher7 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 78
