The 5-door Explorer and its companion the Mercury Mountaineer were redesigned entirely for the 2002 model year, gaining a similar appearance to its big brother, the Ford Expedition.
Get a can of Aerokroil and a heatgun (not a hairdryer) If you use a torch you better be good with it - Much easier to damage stuff with it. Heat each bolt until you can't touch it, then spray the Aerokroil into the seam between the bolt head and caliper. Do this at least twice with a few minutes between. Aerokroil is the best penetrant I've seen. I owned an automotive underbody repair shop for 18 years.
are the bolts super rusty or do you lack the right tools to get them loose?
由 Jesse Hooton 完成的
they r super rusty i bought bolt extractor set from advance but havnt tryed it yet
由 jd77766 完成的
由 Kevin Sargent 完成的
