跳转到主内容
加入维修社区 - 创建账户
Landline phone that includes up to 5 handsets and charging bases. Includes voicemail and speakerphone features.
KX-TG9542B Handset beeps constantly when on charger?
I have the Panasonic 2 line/bluetooth cellular landline phone model KX-TG9542B and the handsets start to beep when on charging stands… it is intermittent… (usually beeping at the worst times like 4am.. etc) I have 5 remote handsets and have tried changing the batteries to fresh Panasonic aaa rechargeable batteries… cleaning the contacts on both the phones and the handsets and nothing seems to help or work? I have other Panasonic cordless phones (single line) in another house and they never beep? this has been going on for years and it is driving me crazy… can anyone please help me?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
No answer from me, but same issue. Maddening.
完成的
Same here. It's as if the phone isn't quite heavy enough to fully seat itself in the charger. So it only makes intermittent contact with charger contacts.
完成的
My Pasonics do it and I have never found the anwer. Anyone had any luck?
完成的
添加一条评论
2个答案
Hi @panahead ,
It's not beeping because you are receiving new messages is it?
Here’s an image that shows how to enable or disable it
(click on image to enlarge for better viewing)
这个答案有帮助吗?
得分 0
3条评论:
Hi Jayeff,
Thanks for your reply… No sadly it isn’t the message beep… it is a constant high pitch beep that seems related to the charging of the handsets? and sadly it is intermittent… like I have said I change the batteries.. clean the contacts and sometimes it seems to help? but it always comes back…
完成的
Hi Jayeff,
It just started to beep after 24 hours on the cradle with brand new batteries… when it beeps the screen on handset blinks from a blank screen to a notice the says “charging”, nothing else on the handset’s screen… and normally when it is on the cradle it shows the regular info… date.. time.. name of handset.. and state of charge… (which is 100%)
完成的
@panahead
How do you stop the phones from "beeping" or do they stop by themselves?
The user manual also says to do what you do when the beeping occurs.
Do you clean all the terminals in the charging circuit i.e. the battery's terminals, the phone's battery connector terminals and also the cradle connectors?
It's very strange that this happens on all 5 handsets. Just wondering if the phones have "serial numbers" and if so are they all consecutive or at least within the same number range? If so then perhaps there was a problem during manufacture
完成的
添加一条评论
I’ve had the same problem with all my three handsets in my vacation home.
I believe it’s a design flaw because this only happens with Model KX-TGL433B I have in my vacation home. In my main home I have five handsets of a different Panasonic model, KX-THD564 that have never had this problem.
My high-tech “solution” to the beeping problem is to put a coin behind the handset when it’s sitting in the cradle in order to tighten the loose connection there is when the phone is in the cradle. It works most of the time, haha.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
panahead 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 64
总计 11,253
