跳转到主内容
加入维修社区 - 创建账户
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
MacBook Pro won't start and won't charge
I have a MacBook Pro (Retina, 15 inches, Mid 2012), recently replaced the battery ourselves with an ifixit kit (MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery, Fix Kit. SKU: EU117047-5). This was fitted at the beginning of February and had given the mac a new lease of life.
But unfortunately, it was being used last week it ran out of charge even though the MagSafe charger had a green light on it, it ran out of power.
I have since tried another power supply that has the same green light on, and also not charging. I have tried resetting the SMC but nothing seems to work or power it up. If I press the power button the no charge icon appears on the screen and the MagSafe light stays green.
Has anyone any ideas? could it be the logic board or is there anything else that can try?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Do you still have your old battery? If you do carefully unplug the installed battery and give your old battery a try placing your system on its side so you can still access the MagSafe port.
Does the charger LED go to Amber and/or will it startup even if you only see the fan move a bit.
完成的
Hi Dan, thanks for the advice. I connected the old battery and the system rebooted and worked, but there was very little power in the old battery and it kept shutting down, but it did reboot. The LED stayed on green and didn’t go Amber, so wasn’t charging the old battery either. Does this mean the logic board is ok? Or does this explain something else is broken. Could it be the MagSafe DC-In Board is faulty? Or does anything else come to mind?
完成的
Further update.
I restarted a few times and couple of times it fully starts up being able to log on, I can see the battery says it’s at least 30% power. But then shuts down before I can do anything else.
Tryed a few more times and now the boot up bar gets to 2/3 along the bar before shuts down.
完成的
添加一条评论
1个答案
已选择的解决方案
@beetlebug - Contact iFixit for a battery replacement! Sorry ;-{ You got a bad battery!
Contact iFixit Customer Support
这个答案有帮助吗?
得分 1
5条评论:
I will contact ifixit about replacing the battery. But I’m still concerned that even with a new battery fitted will it charge?
Because with the old battery connected the MagSafe still isn’t charging this old battery either, so I’m thinking is there any other issue?
完成的
@beetlebug - Yes that's possible! But if you followed the procedure to calibrate your battery you should have noted the MagSafe LED going from Green to Amber and back to Green. Did you not see this? I assume you've been using your system for awhile was the MagSafe ever lit as you used the charger?
I would review this Apple T/N Apple Portables: Troubleshooting MagSafe adapter to make sure your charger is in good shape. Are you using the original charger or a replacement? Most of the knockoff chargers can damage your system!
Don't Replace Your MacBook Charger With a Cheap Knockoff
OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth
Lacking safety features, cheap MacBook chargers create big sparks
FAKE Magsafe MacBook Chargers on eBay - Watch before buying a Mac Charger
Make sure you've got a REAL Apple unit! Apple 85W MagSafe 2 Power Adapter (for MacBook Pro with Retina display)
完成的
Update, I have removed the new ifixit faulty battery and put the old battery back in, which I hadn't disposed of yet. And boots up and the charger is amber charging. But the battery is again showing as 'service battery', in the Energy Saver tab. So the charger is working and I now need to get a replacement battery form Ifixit. At least I know its not the logic board or worst! Thanks Dan for all your help and advice in getting to the bottom of the issue.
完成的
@beetlebug - Sounds good!
Don't forget to score the answer and accept the answer - Thanks!
完成的
Thanks, @danj, I haven't asked any questions before, but hopefully, I have scored and accepted correctly. Thanks again for your help.
完成的
添加一条评论
添加你的答案
Neil Jeremy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 305
