跳转到主内容
Released January, 2009. This device has a larger screen than the normal kindle and supports PDF files.
How do you replace the usb charge port?
kindle dx micro usb replacement. I have to jiggle it to get a steady charge light.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Matt,
You most likely just need to re-solder the connections of the USB socket to the motherboard. Manufacturers nowadays use lead-free solder which is not as durable and certainly not as flexible as the leaded version. If you open the Kindle, just gently wiggle the socket and if it moves then you definitely have a dodgy connection to the board.
If for some reason your pins are bent you can always, try to bend them back to straight or order a new USB socket and solder it on.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Matt Hoffman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 406
