跳转到主内容
Is soldering required to replace *just* the digitizer?
I have a 2nd gen iPad Pro 12.9” and about a month after I bought it, it got dropped and cracked the digitizer. I finally found a decently-priced replacement and was looking at repair videos. To my alarm, it looks like the repair involves microsoldering. Is this the case? Is it literally easier (but ridiculously more expensive) to buy the full LCD assembly with the daughtercard and replace that instead?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Not only it requires soldering but plenty of other tools as well since the digitizer is glued to the display. Display - glue - digitizer - glue - glass. Older iPads had it separate making the replacement a lot easier. The part you need to desolder has chips on it which I believe are married to the motherboard. No matter what screen or digitizer you get you’ll need to desolder it and solder it onto the new assembly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mike Morkes 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 157
