跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Keyboard backlight does not work
Hello,
I changed the motherboard on my MBPR and the keyboard backlighting does not work. Is there another cable especially for the backlighting?
The keyboard works, but the backlighting doesn´t.
Update (03/17/2021)
This is My MacBook. But I can Not find the cable…
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Yes there’s a small cable that connect the keyboard backlight to the logic board. It’s located hinges side to the left of the logic board. It’s very easy to forget to lift up the cable over the logic board during installation. Check the board you should see the small connector. If you don’t see the cable clipped on the connector it should be right there under the logic board.
这个答案有帮助吗?
得分 1
添加一条评论
Looks like you still have it tucked under the logic board!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eric Reinhardt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 125
